Neue Liste "empfohlener" Objektive für die D800E
veraikon
Beitrag von veraikon »
http://nps.nikonimaging.com/technical_s ... ips/d800e/
With cameras like the D800E, which are suited to photography of visually complex subjects, maximizing lens resolution is vital. Though results will vary from lens to lens, the greatest contrast all the way to frame peripheries can generally be achieved at an aperture setting two to three stops down from maximum aperture. Some lenses that offer excellent resolution are listed below.
* AF-S NIKKOR 14-24mm f/2.8G ED
* AF-S NIKKOR 24-70mm f/2.8G ED
* AF-S NIKKOR 70-200mm f/2.8G ED VR II
* AF-S NIKKOR 70-200mm f/4G ED VR
* AF-S NIKKOR 16-35mm f/4G ED VR
* AF-S NIKKOR 24-85mm f/3.5-4.5G ED VR
* AF-S NIKKOR 24-120mm f/4G ED VR
* AF-S NIKKOR 200-400mm f/4G ED VR II
* AF-S NIKKOR 24mm f/1.4G ED
* AF-S NIKKOR 28mm f/1.8G
* AF-S NIKKOR 35mm f/1.4G
* AF-S NIKKOR 85mm f/1.4G
* AF-S NIKKOR 85mm f/1.8G
* AF-S NIKKOR 200mm f/2G ED VR II
* AF-S NIKKOR 300mm f/2.8G ED VR II
* AF-S NIKKOR 400mm f/2.8G ED VR
* AF-S NIKKOR 500mm f/4G ED VR
* AF-S NIKKOR 600mm f/4G ED VR
* AF-S Micro NIKKOR 60mm f/2.8G ED
* AF-S VR Micro-Nikkor 105mm f/2.8G IF-ED
* PC-E NIKKOR 24mm f/3.5D ED
* PC-E Micro NIKKOR 45mm f/2.8D ED
* PC-E Micro NIKKOR 85mm f/2.8D
The D800E offers better resolution at aperture settings with which diffraction is not an issue. As the aperture setting has more influence on resolution with the D800E than with the D800, D800E users should always keep the possible effects of diffraction in mind.
Stand : 02.Mai 2013
In Ergänzung hier der Thread in "unserem" Forum der sich mit MF-Objektive und D800/E beschäftigt
(also auch die die via Nikon neu beziehbar sind aber nie und nimmer in o.g. Liste auftauchen werden ;) ,ebenso wie die die nicht mehr neu beschaffbar sind):
http://www.nikonpoint.de/viewtopic.php?t=80181/
( NB: keine _offizielle_ Nikon-Liste !! )
PS: Link zugefügt.
Danke,
brauch' ich also doch kein 800er bestellen :bgrin:
Kann mir mal einer erklären warum das 16-35 und 24-120 in der Liste ist und das 50 1,8 fehlt?
Nach welchen objektiven Kriterien wird denn die Liste erstellt?
Spellie
Beitrag von Spellie »
Umsatz ;)
Andreas G hat geschrieben: Nach welchen objektiven Kriterien wird denn die Liste erstellt?
Vermutlich danach, ob die Linse den goldenen Ring hat oder nicht. Oder aber ob der Anschaffungspreis eine gewisse Mindesthöhe hat.
Denn es ist wirklich merkwürdig, was hier mitunter aufgeführt und bei und hier im NP als nachweislich "jetzt nich sooo" ist.
Fotograf58
Beitrag von Fotograf58 »
FM2-User hat geschrieben:Danke,
Das spart viel Geld :bgrin: .
monchichi
Beitrag von monchichi »
Da haben sie aber z.B. dasAI-s 200/4 vergessen :P
veraikon
monchichi hat geschrieben:Da haben sie aber z.B. das AI-s 200/4 vergessen :P
Nö, nicht vergessen, in der Liste erscheinen nur "aktuelle" Objektive ;)
joerghey
Beitrag von joerghey »
Philip, Du meinst denke ich das 4/200 Micro !
Das gibts ja eigentlich noch als AF-Version, das gehörte von der Abbildungsqualität sicher mit in die Liste.
Grüße, Jörg
monchichi
Ich mein das Ai-s :super: Das Mikro ist sicher auch klasse, aber das hab ich noch nicht an einer E im Einsatz gesehen.
