Vivitar Series 1 90-180mm 4.5 Flat Field Macro AI-S
Dane
Beitrag von Dane »
Technische Daten:
Focal length: 90-180mm
Filter thread: 72mm
Min. Aperture: f/4.5
Max. Aperture: f/22
Angular field of view (diagonal): 27°
Elements/groups: 18/12
Min. focusing distance: 27" (68.6 cm) @ 180mm
Max reproduction ratio: 1:4 @ 90mm, 1:2.7 @ 135mm, 1:2 @ 180mm
Weight: 2.4 lbs. ( 1.1 kg)
Infos:
Vivitar made a number of high quality zooms under the Series I label. The 90mm to 180mm f4.5 flat-field VMC lens from 1978 is an one of them.
This Vivitar 90-180mm f/4.5 lens was really designed for medical photography needs. A ring-light flash unit was designed to mount on the front of this lens too. This original medical market niche explains some of the design features and range of this high quality zoom lens.
This lens is long, and pretty heavy. It produces excellent results in macro-work down to 1:4 at 90mm and to 1:2 at its 180mm setting.
On most modern zoom lenses, macro photography settings are a lower quality setup. Achieving macro capabilities means shifting some elements and so sacrificing some of the zoom's control over spherical and other aberrations.
Most current zooms only offer macro settings at either one end or the other of their range. Only a few zooms offer continuous macro-settings over their full range. Even the better current zooms generally only get to 1:4 to 1:6 reproduction ratios (.e., the object is one-fourth lifesize on film).
The Vivitar 90-180mm f/4.5 Series I macro zoom is designed to provide the highest possible quality continuously down to its closest macro settings. The Vivitar 90-180mm f/4.5 flat-field lens provides high quality macrophotography continuously from 90mm (to 1:4) to 180mm (to 1:2). That's unique, and useful, so you should expect to pay quite a price premium for such a lens!
(Source: Cult Classics in Third Party Lenses by Robert Monaghan )
Ein seltenes Highlight war das äußerlich eher unauffällige Serie 1 4,5/90-180 mm Flat Field Macro Zoom (18 Elemente in 12 Gruppen). Ursprünglich für de medizinische Photographie entwickelt, war es nach zeitgenössischen Tests das beste Zoom für Nahaufnahmen überhaupt.
Links:
Dane
Beitrag von Dane »
Nach länger Zeit habe ich nun ein Objektiv gekauft,
nach dem ich schon lange gesucht habe.
Da mich in jüngster Zeit gerade die Vivitar Objektive interessieren,
(Woran das 90mm 2.5 Macro Schuld ist) wollte ich die Gelegenheit,
es nur 15 Minuten von mir entfernt zu kaufen, beim Schopf ergreifen.
Das Vivitar 90-180 ist wie das Nikkor 70-180 ein echtes Macro Zoom
und wurde für die medizinische Fotografie gebaut.
Es hat eine angenehm dimensionierte Stativschelle,
die die Arbeit im Macrobereich als Zoom weiter unterstützen dürfte.
Die Gegenlichtblende werde ich definitiv auch noch besorgen,
nun hoffe ich erst einmal auf einen guten Zustand, da ich es erst morgen abholen kann..
Dane
Beitrag von Dane »
Habs :super: :super: :super:
Ein TRAUM von Objektiv.
Richtig schwer, wie neu, alles läuft satt wie am 1. Tag.
Blende NICHT (!) verölt und snappy (!).
Ausreichend stabile Stativschelle direkt dran - toll!!!
Auf den ersten Eindruck wirklich GENIAL - eine Kaufempfehlung von mir für alle :super: (werde hier weiter testen und updates bringen) :cool:
Hier ein paar erste Impressionen ohne künstlerischen Wert, nur kurzer Schärfe, Farben, Kontrasttest.
Unverändert bis auf Schärfen. (Meine Standart-Einstellungen)
Dane
Beitrag von Dane »
Duvel
Beitrag von Duvel »
Schöne Bilder, vor allem die ersten drei aus der zweiten Serie.
Wie würdest du die Linse im Vergleich zum Micro Nikkor 70-180 sehen? Ist das Vivitar auch parfokal?
Dane
Beitrag von Dane »
Leider ist es nicht parfokal, man muss minimal nachfokussieren nach dem Zoomen.
Optisch und haptisch ist das Vivitar ein Traum. Bei Offenblende war meine ich das Nikkor etwas schärfer, dafür hat das Vivitar die konstante Lichtstärke über den gesamten Brennweitenbereich.
Zudem war beim Nikkor das Problem, dass die Brennweite konstruktionsbedingt verkürzt wurde, um zum max. Abbildungsmaßstab zu kommen. So entsprach es bei 1:1,3 einem 90er Makro.
Das Vivitar dagegen ist ein "echtes" 180mm 4.5 Makro mit 1:2.
Und dadurch eine echte Ergänzung zum Bokina.
Beim Bokeh im normalen Tele Einsatz war das Nikkor :(( :(( :(( ,
das Vivitar ist hier auch keine Konkurrenz fürs Bokina, aber deutlich angenehmer. ;)
Berücksichtigt man Preis / Leistung, ist das Vivitar 90-180 ohnehin WEIIIIIIT vorn gegenüber dem Nikkor, wenn man eines findet und es auch noch in gutem Zustand ist.
Duvel
Beitrag von Duvel »
Ich sehe gerade, noch zwei Linsen, dann ist alles Vivitar :hmm:
Dane
Beitrag von Dane »
Jop, die hatte ich großteils noch nicht getestet. ;)
Und ggf. kommt die Tage noch ein Vivitar Series 1 28mm 1.9 dazu :bgrin:
Ich neige aber dazu "fan"atisch zu sein… So kennt ihr mich doch :cool:
Die Verarbeitungsquali und das Preis/Leistungsverhältnis ist aber auch toll :super:
Zuletzt geändert von Dane am So 19. Okt 2025, 09:58, insgesamt 1-mal geändert.
Dane
Beitrag von Dane »
Der Frühling naht :super: :super:
Bull 38
Beitrag von Bull 38 »
Hej, das 90-180 gibt ja was her. :super:
