D300 Firmware Version 1.10 (EN)
Gesperrt
mod_ebm
Technischer Admin
Technischer Admin
Beitrag von mod_ebm »
Nikon scheint die Nacht Version 1.10 für die D300 veröffentlicht zu haben. Für die, die des englischen mächtig sind hier die lange Liste der Änderungen, unten der Link.
Modifications enabled with upgrade of A and B firmware from Ver. 1.03 to Ver. 1.10
* The Highlights playback display option has been moved from Display mode>Basic photoinfo>Highlights in the playback menu to Display mode>Detailed photoinfo>Highlights.
* The size and color of “Demo” displayed in the monitor with playback when No memory card? in the Custom Settings is set to Enable release, have been modified.
* The range of settings available for ISO sensitivity settings>ISO sensitivity autocontrol>Minimum shutter speed in the shooting menu has been increased from 1/250–1 s to 1/4000–1 s.
* When shooting in hand-held live view mode and the frame is magnified prior to autofocusing, operation has been modified so that display returns to the magnified display rather than full-frame display.
* Images captured with Rotate tall, in the playback menu, set to On are not automatically rotated for display immediately after capture (image review).
* A Copyright information item has been added to the setup menu. When Copyright information is enabled, the copyright symbol (©) is shown in the shooting info display.
* Recent settings can now be displayed in place of My Menu.
* Custom Setting e3 Flash cntrl for built-in flash (e3 Optional flash when an optional Speedlight is mounted on the camera) can now be added to My Menu using the Add items option in My Menu from Add items>Custom settingmenu>e Bracketing/flash.
* The degree of the High ISO NR setting can now be confirmed in the shooting info display while the High ISO NR setting item, in the shooting menu, is being applied.
* Ankara, Riyadh, Kuwait, and Manama have been added to the Time zone options for the World time item in the setup menu.
* When a GPS device is used and no heading information is available, ---.--° is now displayed for the Position>Heading option in the GPS item in the setup menu.
* When shooting in live view mode using Camera Control Pro 2 (Ver. 2.2.0 or later) with a PC-E lens, the aperture setting can now be adjusted from the computer.
* Focus acquisition performance in dynamic-area AF mode has been improved.
* Focus acquisition performance with contrast-detect AF has been improved.
* Auto white balance performance has been improved.
* The fourth digit in seconds display for GPS latitude and longitude information is now rounded off rather than omitted.
* The current MB-D10 battery type setting can now be confirmed in the shooting info display when R6/AA-size batteries are used with the Multi-Power Battery Pack MB-D10.
* An issue that caused an increase in noise with shooting in [M] exposure mode at a shutter speed setting of bulb with the shutter held open for less than 8 seconds and Long exp. NR enabled has been resolved.
* An issue that prevented shutter release at the specified shutter speed when no operations were performed for 30 seconds in mirror up mode has been resolved.
* An issue that caused abnormal image display when Image review was set to On and the playback zoom in button was pressed immediately after shooting at the following settings has been resolved.
o Image quality: NEF (RAW ) + JPEG
o NEF (RAW) recording: Lossless compressed or Compressed
o Image size: S or M
* When the Speedlight SB-800 was mounted on the camera with flash mode set to distance-priority manual (GN) mode, and the camera recovered from standby mode triggered by the auto meter off function, the distance information displayed on the SB-800 changed. This issue has been resolved.
For further information regarding the new firmware, download the supplemental document for the new firmware, D300_FirmUp_(11)En.pdf. Adobe’s Acrobat Reader must be installed on your computer to view this file.
Precautions
* Immediately after the camera’s A and B firmware is updated to Ver. 1.10, the ISOsensitivity settings>ISO sensitivity autocontrol>Minimum shutter speed setting will shift to a faster shutter speed.
* Settings data saved with A firmware Ver. 1.03/B firmware Ver. 1.03 or earlier using the Save/load settings option in the setup menu cannot be read by the D300 after A and B firmware are updated to Ver. 1.10.
* Microdrives cannot be used to perform this firmware upgrade.
* If the downloaded firmware will be copied to a CompactFlash memory card, do not use the Lexar Media JumpShot USB cable. The firmware may not be upgraded correctly.
Auto ISO bis 1/4000s und das ©-Symbol sind wohl die auffälligsten Änderungen ;)
Link zur Firmware auf Nikon USA
Gruß Carsten
Gesperrt
