Hallo zusammen, gerade erschienen das neuste Update von CNX 1.2.Läuft jetzt schneller meiner Meinung nach.
Wo kann man denn nachlesen was verbessert wurde?
Mfg
Thorsten
Update Capture NX 1.2
Re: Update Capture NX 1.2
Hier: ftp://PitTyy9S:gioCouLP@ftp.nikon-euro.com/Software/WcJMGNhhgh/nx12_en.pdflangschiffe hat geschrieben: Wo kann man denn nachlesen was verbessert wurde?
Also ich finde es immer noch sehr langsam :/ (X2 3800+, 2gb ram)
€: jetzt sollte der link eigentlich gehen...
Zuletzt geändert von Fritz42 am Di 7. Aug 2007, 14:25, insgesamt 1-mal geändert.
"Capture NX Version. 1.2.0
Items addressed with Version 1.2.0 update Windows and Mac
? The speed of opening images has been improved.
? When any of the operations listed below are performed, “updating image” is now displayed in the image
window title bar. Enhancements and other operations can still be performed while “updating image” is
displayed. (with Apple Mac computers this occurs with Mac OS X version 10.4 or later)
-An image is opened
-A different version is selected from the Version menu
-Revert is selected from the File menu
? When Open With... is selected from the File menu for an image saved to CD-R or other non-recordable
medium, the image is first copied to a separate location and then opened in the other application.
? When Show Lost Shadows was selected from the View menu, and then display ratio of the image
reduced, the range of lost shadows changed. This issue has been resolved.
? When the size or resolution for an image was specified with selection of Size / Resolution... from the Edit
menu and the setting saved with Save Settings... in the Batch menu, the aspect ratio of processed
images was incorrect when the saved settings file was used with batch processing of images captured in
different orientations. This issue has been resolved.
? An issue that caused RAW images captured with the D1X at an ISO sensitivity setting of ISO 570 to
appear completely black has been resolved.
? An issue that caused images to be affected when saved with a high Radius value in the Gaussian Blur
palette (Adjust menu>Focus>Gaussian Blur...) has been resolved.
? An issue that prevented display of the Color Lightness, Chroma, and Hue width sliders in the LCH palette
has been resolved.
? When Hue and other settings in the LCH palette were saved with Batch>Save Settings... and these
settings then applied to a different image, setting values were sometimes incorrect and points would not
move. These issues have been resolved.
? An issue that sometimes prevent proper Set Gray Point operation from Base Adjustments>Camera
Adjustments>White Balance has been resolved. "
p.s.: Also im wesentlichen "Bugfixes"... da wäre eine Versionsnummer 1.11 angebrachter...
p.s.2: Man muss als Benutzer angemeldet sein... sonst wird das nix mit dem Download...
-An image is opened
has been resolved.
Oder 1.1.4 -- immerhin gab es ja auch eine 1.1.3. Aber vielleicht wurde intern einiges an Weichen gestellt für die Zukunft und so die Änderung auf 1.2 gerechtfertigt.
Vielleicht integriert man ja gerade das eingestampfte Nikon View Pro (oder wie hieß es noch?) um LR ein wenig Konkurrenz machen zu können...
Lars
Lars
langschiffe
Download von der europäischen Downloadseite klappt einwandfrei.
Die Änderungen sind auf Deutsch dokumentiert.
Bilder laden geht tatsächlich schneller und so manche Kinderkrankheiten scheinen behoben zu sein, wenngleich es noch einiges zu verbessern gäbe.
mfg mh
http://tinyurl.com/387psv
mfg mh
Zuletzt geändert von htz am Di 7. Aug 2007, 22:01, insgesamt 1-mal geändert.
