Ich weiss nicht, wie tief Ihr in den Link auf Harbortronics eingestiegen seid, aber da ist ein Detail in den FAQ, das ich schon interessant finde:
Hier gibts doch einige Bastler, die sich auch an Mattscheiben herantrauen -- will das nicht mal jemand versuchen?Can we modify the camera ourselves?
Absolutely… it’s your camera after all. If you have the tools and ability, by all means give it a try. It’s a fairly simple connection, wiring the camera’s shutter release switches to a stereo 2.5mm jack (only 3 wires). Unfortunately you have to completely remove each and every part of the camera’s case (about 30 screws in total, #00 Philips screwdriver), acquire the right jack for the job, find a way to mount it just perfectly, route the wires through the camera body, soldering the wires to the right places inside the camera and on the jack. If this sounds scary to you, then you should perhaps leave it to someone else. I’ve already modified over 25 cameras, and the number continues to rise. There’s some value in expertise! If this sounds like fun to you however, go to it! We are not interested in selling a modification kit nor plans however, given the delicate nature of the task.
Immerhin gewinnt man dadurch auch ganz generell einen Fernsteuerungs-Anschluss, nicht nur für den Batteriegriff ...
-- snorri
