Voigtländer Color Skopar 28mm 2.8 SL II N
Dane
Beitrag von Dane »
Michael_Leo hat geschrieben:Zumal bei eingeschraubter Geli ja wohl der Objektivdeckel nicht mehr drauf geht. Das bin ich vom 2,8/45 AI-P anders gewohnt. Die Voigtländer-Geli wirds damit schonmal nicht.
Mit der Geli wird ein passender anderer Deckel mitgeliefert, damit ists genau wie beim 45mm 2.8 ein Traum.
Ich habe noch einen UV FIlter IN die Geli geschraubt, so putzt dieser sich leichter ohne dass ich die Geli abnehmen muss.
Ausserdem ists so ergonomischer, weil sonst der UV FIlter doch etwas unkomfortabel aufbaut.
Dane
Re: Voigtländer Color Skopar 28mm 2.8 SL II N
Beitrag von Dane »
Das ‚neue‘ scheint tatsächlich neu gerechnet zu sein oder? Oder „nur“ der verlängerte Schneckengang?
https://www.cosina.co.jp/voigtlander/en ... cal-sl-ⅱs/
The barrel design, which is homage to the era when it was something quite special to own a camera, is equipped with an optical system of 5 elements in 6 groups that uses double-sided aspherical element. A wide-angle lens with sharp image quality up to the periphery. The focusing unit is equipped with a helicoid ring with an extra-long extension amount, achieving a minimum shooting distance of 0.15 m. Dynamic drawing is possible by taking advantage of the wide-angle lens perspective.
Main Features
Sharp imaging up to the periphery of the screen
By adopting a double-sided aspherical element, sharp image quality is maintained up to the periphery.
Design that combines nostalgia and functionality
The focus ring and aperture ring are made entirely of metal, and the knurled pattern, which has been heavily machined and precision-cut, is not only nostalgic and beautiful, but also has functionality that enhances the feeling of manual operation.
Manual focus for reliable focusing
By adopting an all-metal helicoid unit processed and adjusted with high precision and high-quality grease that produces an appropriate torque, focusing with a smooth operation feeling is realized. It enables fine focus adjustment.
Choice of barrel design variations
Beautiful in appearance as well, it is available in both “white rim” and “black rim” variations paying homage to lenses of the 60’s and 70’s.
Usable on a range of bodies
The lens mount is interchangeable with Nikon Ai-S with built-in CPU. In addition to a built-in CPU, the lens also has an Ai coupler, so that the lens can be used on a wide range of camera bodies from the old film cameras of yesteryear through to the latest digital single-lens reflex cameras.
Lens diagram
Focal Length: 28mm
Aperture Ratio: 1 : 2.8
Minimum Aperture: F22
Lens Construction: 6 groups 7 elements
Angle of View: 74.8°
Aperture Blade: 9
Minimum Focus: 0.15m
Maximum reproduction ratio: 1:2.3
Diameter × Length: φ66.3×32.8mm
Filter size: φ52mm
Weight: 205g
Mount: Ai-S (CPU integrated)
Hood: LH-28 IIS (Optional hood)
Dane
Beitrag von Dane »
Hatte das neue da, die Nahgrenze ist schon nett - es ist auch überraschend scharf an dieser !
Haptik wie immer ein Traum. Der längere Schneckengang wird halt durch mehr Baugröße erkauft.
Mir wars das nicht Wert - ich habe mir daher lieber die "alte" Variante gekauft :super:
