Hallo MF-Spezies,
seit Lichjahren besitze ein Vivitar Series 1 35-85/2,8 Schiebzoom.
Leider mit M42 Anschluß
Es gab dieses Zoom auch mit Nikon-AI Anschluß.
Lohnt sich eine Umrüstung?
Danke schon mal für eure Tips
Vivitar Series 1 35-85mm 2.8
Also die beendeten Angebote in der Bucht sprechen eigentlich für einen Kauf (und nicht für einen Umbau) der Nikon Version. (um 50€ gebraucht)
Da wäre mir der Aufwand zu groß.
Name: Vivitar Series 1 35-85mm f/2.8
Zoom/Prime: Zoom
Focal Length: 35-85mm
Maximum Aperture: f/2.8
Minimum Aperture: f/16
Diaphragm Blades: 6
Serial Number (or Approx.): 22******
Sonst habe ich nur gefunden, dass es von Kiron produziert wurde.
__________________________________________________________________________
O-ton im Netz bisher:
1.von laurphoto:
"The Vivitar Series 1 35-85/2.8 is a very well built push-pull zoom. It is a varifocal design, meaning that focus will shift during zooming - this allows the lens to be relatively compact. The front element is quite large - the lens takes 72mm filters - and it is also prone to flare - it is essential to use a hood with this lens or the images will come out as washed out. It was effectively impossible to use this lens in daylight until I could get a hood for it. Bottom line - the Vivitar Series 1 35-85/2.8 lens has a great build, but the optical quality does not live up to its "cult lens" status."
2.Rating von Steve_FE auf FlickR
"Product Ratings (1=miserable, 5=excellent):
Construction Quality: 4
Image Quality: 2 - 4 (see review!)
Overall Value For Price: 4 (40€!)
Recommended: With reservations
It doesn't seem especially sharp wide open, although it's certainly usable. From pure empirical looks at my own pics I'd say the Tamron SP35-80 edges it on sharpness every which way. Like most lenses it improves stopped down.
It is quite prone to that fuzzy purple fringing/halo thing on small highlights used wide open, which gives the impression of more softness than is maybe actually there; again this gets better stopped down.
The bokeh quality varies wildly depending on focal length and aperture - good bokeh's not something you'd necessarily be buying a zoom for, but you might hope for it in a fast one. It's worst at 35mm wide open, quite truly distracting and hideous, but really not too bad when it's stopped down or moved out towards 85mm. "
Im Netz gibts noch viel mehr dazu...
Wie waren denn Deine bisherigen Erfahrungen?
Oder hast es mal gekauft und nie benutzt?
Zoom/Prime: Zoom
Diaphragm Blades: 6
1.von laurphoto:
Danke Dane
Es ist schon eine Ewigkeit her, das ich dies Zoom benutzt habe.
Ich hatte es an einer kuriosen Ricoh TLS 401
Für Porträts was das Zoom an 85mm ok.
An der F2 war es ein Ticken schärfer...
Aber was ich so dank deiner Auflistung lese, lohnt sich ein Umbau auf Nikon-Bajonet nicht wirklich.
Vielleicht kriege ich mal ein abgerocktes Exemplar, an dem das Bajonet noch ok ist und dann schaue ich mal, ob der Umbau für mich machbar ist.
Vielen Dank für deine Hilfe und die guten Infos
Keine Ursache - macht Spaß
Zum Umbau: Oder gleich als N/AI kaufen und das M42 verkaufen - soviel differenz dürfte da nicht zwischen liegen..
PS: Hier Bilder auf FlickRiver mit dem Objektiv
Klasse Dane,
mein Zoom (Sogar mit Orginal-Geli) ist noch super in Schuß und deshalb möchte ich das lieber selber nutzen
Die Beispielbilder aus FlickRiver sind teilweise sehr vielversprechend
Muss ich mir alles noch mal durch den Kopp gehen lassen
Danke dir und ich wünsche noch einen schönen Sonntag
