Wie macht ihr euren Sensor sauber...
Hans-Joachim
Re: Silikonschlauch
Beitrag von Hans-Joachim »
David hat geschrieben:
Elwood hat geschrieben:
Hans-Joachim hat geschrieben:100% Methanol.
Woher weisst Du die genaue Zusammensetzung?
Sämtliche Testerquellen berichten dies. Und ich glaube es steht sogar drauf. :) :cool:
http://www.fotocommunity.de/info/Sensorreinigung
Es steht drauf:
Contains Methanol. Product burns with no visible flame. Keep away from heat, flame, sparks and ignition surces. Do not get in eyes. Irritation may occur. Wash eyes thoroughly with plenty of fresh water.Harmful if swallowed. Induce vomitting. Avoid breathing vapor. May cause dizzines headache or nausea. Use only in a well ventilated area. For mor information refer to MSDS.
Bei MSDS kann man dann dieses hier lesen:
MATERIAL SAFETY DATA SHEET (MSDS)
E-WIPE®; & ECLIPSE®;
Section I Chemical Product & Company IdentificationPreparation Information : This MSDS was prepared by David M. Stone, President, PHOTOGRAPHIC SOLUTIONS, INC.
date prepared : 03 Jan 2006
Product Identifier : Eclipse®; Optic Cleaner or e-Wipe®; Critical Optic Cleaner
Manufactured by : PHOTOGRAPHIC SOLUTIONS, INC.
260 Main Street , Buzzards Bay, MA 02532
Emergency Phone : CHEMTREC (800) 424-9300 24 hours / 7 days
Product Use :
Eclipse is intended for cleaning optical lenses such as those used in photography, binoculars, telescopes, etc. It is applied by dropping a few drops onto a clean PEC*PAD®; and wiping across the surface of the glass.
e-Wipe is intended for cleaning critical optic CCD's, mirrors and lenses such as those used in digital camera and photographic equipment, binoculars, telescopes, etc. It is applied by opening the sealed packet and gently wiping in a single direction across the surface.
Section II Composition and Ingredient Information
Chemical Identity : 100% Methanol - CAS # 67-56-1
Section III Hazards Identification
FLAMMABLE LIQUID - Product can burn with no visible flame.
viele Grüsse
Hans-Joachim
D200 / AF-S DX Nikkor 18-70mm f:3,5-4,5 G / AF-S DX VR Nikkor 18-200mm f:3,5-5,6 G IF-ED / SIGMA 10-20mm F:4-5,6 DC HSM; SIGMA 105mm f:2,8 EX DG MACRO / Nikkor 50mm f:1,8 / SB-800
olivers
Beitrag von olivers »
Also ich nehme auch den Staubsauger zu hilfe.
Halte meine Hand vor das Rohr und an das Bajonett und schwuuupppss der staub ist verschwunden aber achtung den Staubsauger nicht auf volle leistung stellen sonst ist der Spiegel auch noch weg.
Gruß, Oliver
Elwood
Re: Silikonschlauch
Beitrag von Elwood »
Hans-Joachim hat geschrieben: Section II Composition and Ingredient Information
Okay, danke fuer die Info. Auf der Flasche/Karton steht in der Tat dass
es Methanol enthaelt, aber das sagt ja nichts ueber andere nicht
deklarationspflichtige Bestandteile wie demineralisiertes Wasser aus.
Oft wird ja auch ein Gemisch mit Demin und Aether als
Optikreinigungsmittel empfohlen, weil der Alkohol sonst zu schnell
verdunstet; daher meine Neugier.
Ausserdem konnte ich am Flaeschen keinen starken Alkohol
geruch wahrnehmen.
Wie auch immer, das Zeug ist wirklich gut und wenn ich damit nur meine
Sensoren reinige, komme ich noch 250 Jahre hin. Danach werde ich ein
Flaeschen Methanol bei meinem notleidenen Apotheker erwerben. ;-)
Hans-Joachim
Re: Silikonschlauch
Elwood hat geschrieben: Ausserdem konnte ich am Flaeschen keinen starken Alkohol
geruch wahrnehmen.
Das solltest du nicht so oft machen.
Methanol ist seeeehr giftig.
Wikipediaauszug:
Dosen von 0,1 g Methanol pro kg Körpergewicht sind gefährlich, über 1 g pro kg Körpergewicht lebensbedrohlich. Die Vergiftungssymptome einer Methanolintoxikation verlaufen in drei Phasen. Direkt nach Aufnahme von Methanol zeigt sich wie beim Ethanol ein narkotisches Stadium, die berauschende Wirkung ist jedoch geringer als bei Ethanol. Nach der häufig asymptomatischen Latenzphase treten Kopfschmerzen, Schwächegefühl, Übelkeit, Erbrechen, Schwindel, beschleunigte Atmung auf - die Folgen der sich ausbildenden metabolischen Azidose. Charakeristisch ist die Schädigung von Nerven, insbesondere am Auge. Netzhautödeme bedingen ein nur noch verschwommenes Sehen und können zur irreversiblen Erblindung führen. Der Tod kann als Folge einer Atemlähmung eintreten.
viele Grüsse
Hans-Joachim
David
Re: Silikonschlauch
Beitrag von David »
geruch wahrnehmen.
Wikipediaauszug:
Deswegen rücken die Apotheker das Zeug ja auch meistens nicht raus. :) :!:
Photoshark
Beitrag von Photoshark »
Ich habe die einfache Anleitung mit bestem Erfolg angewendet: In der Apotheke für 70 ct. 10 ml absolut reines 2-Propanol, auch als Isopropylalkohol oder Isopropanol (abgekürzt IPA) bekannt, gekauft, dazu medizinische Wattestäbchen, Tropfen auf das Stäbchen, Sensor meiner D50 mehrfach ganzflächig abgewischt, Kontrollfoto gemacht, das noch ein paar Staubkörner zeigte, an den Stellen gezielt mit noch einem Tropfen nachgewischt und fertisch. Sensor wieder völlig sauber.
Ob ich das so lapidar gemacht hätte, wenn ich eine D200 oder D2(x/s) mein Eigen nennen würde, weiß ich nicht. Da hätte ich mir vielleicht für 35 € diese Wipes bestellt.
D50 | F70 | 18-55 | 28-80 3.5-5.6D | 70-300 4-5.6 D ED | 50 1.8 | SB-600 | Wunschliste: Nikon 18-200 / Tokina 12-24 / Manfrotto 055PROB+322RC2
Herbert
Beitrag von Herbert »
Herbert hat geschrieben:Scheuermilch....... :cool:
Nun im Ernst....
Ich traue mir selbst eine Reinigung ehrlich gesagt nicht zu und geh lieber einmal im Jahr zu Nikon nach Düsseldorf.
Photoshark hat geschrieben:
Meinst du die Sensor Swabs ? Wo kriget man die für 35€. Ich habe die bei shop.multimedia geshene für 65€.
Elwood
Herbert hat geschrieben:Ich traue mir selbst eine Reinigung ehrlich gesagt nicht zu und geh lieber einmal im Jahr zu Nikon nach Düsseldorf.
Und nachdem ich gesehen habe, wie die da rangehen mach ich es lieber
selber. Ich hab dann doch mehr Respekt vor meinen Kameras ;-)
@zappa4ever: Sensor Wands und Pec-Pads ! Ihr solltet Euch Dirks Artikel
wirklich mal durchlesen! Und das gibts in DL bei micro-tools.com in Gronau.
Auch die Pec-Pads sind geniale Tuecher. Reissfest und Fusselfrei.
Wenn Du dagegen mal ein Wattestaebchen unter dem Mikroskop
anschaust ...
Fuer Wands, Pec-Pads, Eclipse und Porto kommt man dann auf ca. 35 Euro.
Swaps sind fuer Leute, die nicht imstande sind die Tuecher um die
Wands zu wickeln (ist wirklich ein bisschen frickelig und das schwierigste
an der ganzen Prozedur, aber zweimal im Jahr bekommt man das schon
hin) oder sich die Reinigung mit 40 Euro bezahlen lassen.
- Juergen -.
Elwood
Re: Silikonschlauch
Hans-Joachim hat geschrieben:Das solltest du nicht so oft machen.
Wikipediaauszug:
Ich rede von riechen, nicht trinken! Ich habe sicher keine 8 Gramm eingeatmet.
Trotzdem danke fuer den Hinweis!
